Open VI Reference Function and a RUN VI RUN VI Method Causes Error 1000 with version 2014
Thanks JWCS
I read that yesterday and am able to launch the VI by itself.
Also, it does not appear to be open when stepping through the
application.
Message 11 of 44
(2,210 Views)
In VI properties -> Execution, make sure that Run When Opened is unchecked.
aputman
Message 12 of 44
(2,202 Views)
Thanks Aputman
This are how the Execution VI Properties are set:
Message 13 of 44
(2,195 Views)
@Norbert_B wrote:
Have you compiled that "plugin" VI with LV 2014?
I have just mass compiled everything in the folder (and sub-folders) where my code is with version 2014
then rebuilt the executable and then rebuild the installer.
I installed this one my test system and still receive the error 1000
Message 14 of 44
(2,190 Views)
Hi robojeff,
I notice in your first post that you are using LabVIEW 2014 with Windows 10.  This could be the source of the issue because Windows 10 is only compatible with LabVIEW 2015 SP1 or newer, as is shown on this compatibility document.
Do you have access to LabVIEW 2015 SP1 or newer to try with your program?  If not, you can download an evaluation for LabVIEW 2016, or revert your OS to an older version.
-cblanchard
Message 15 of 44
(2,156 Views)
@cblanchard wrote:
[...]  This could be the source of the issue because Windows 10 is only compatible with LabVIEW 2015 SP1 or newer, as is shown on this compatibility document.  [...]
This is not necessarily true. The compatibility chart only shows what is officially supported, hence what is being tested at NI.
Experience shows that older versions of LV have no issue running on Windows 10 at all. However, when an issue occurs, you have no support entitlement on that combination esp. if a newer version of LV solves that issue on that OS.
@But it is a good point @Op:
Can you double check if updating LV resolves the issue?
Norbert
Expert: Geometry
Message 16 of 44
(2,141 Views)
I loaded an evaluation copy of LabVIEW 2015 and when I run it I get the same error...
I have an old copy of the exe of this that was made some years ago by someone no longer with the company
but I don't know what version it was created by but it runs just fine
Message 17 of 44
(2,118 Views)
Can you attach an excerpt of your application which shows the issue?
Norbert
Expert: Geometry
Message 18 of 44
(2,113 Views)
Actually, the problem is most likely that it can't find the VI.  I believe Labview 8.6 is one of the versions that lumps all of the VI's into a single directory under the EXE so that you only have to call the VI by name.  In newer versions, however, the EXE directory structure mimics the project directory unless you have the build flag "Use LabVIEW 8.x file layout" set to TRUE.  You'll need to specify a path relative to the application directory or the calling VI path.
aputman
Message 19 of 44
(2,107 Views)
It's not quite as you describe it. There is the LabVIEW 8.x file layout (same is basically used in LabVIEW before 8.x), which is basically all the code packed into an LLB and then put inside the EXE. This results in a single (virtual) folder with the EXE name and all the VIs inside this single folder. However this creates problems with name spaced VIs inside VI libraries and classes as there the VI's in different classes or libraries can have the same name, resulting in naming conflicts when put in a single folder. So they introduced in 8.6 or so a new format where the entire hierarchy is more or less packed into a ZIP file and then put inside the EXE. This allows to have class method VIs and library VIs with the same name to be stored inside the EXE instead of alongside it.
However this changes the path to the VI inside the executable, which your code needs to account for. And yes there seems to be a workaround for the old layout that Open VI Reference attempts to load a VI from inside an executable when only given a path. But if you wire in the IDE only a string to the Open VI Reference instead of a path, the VI must be definitely already in memory for the Open V Reference to succeed!
The quick workaround might be to enable the "Use LabVIEW 8.x file layout" option in the Advanced Settings for your application build. But I'm not sure that the Open VI Reference after 8.6 will actually attempt to load a VI not already in memory, when called with a string input only.
Rolf Kalbermatter  My Blog
Message 20 of 44
(2,092 Views)
