Open Reference VI dependent on file size?
I am using Open Vi reference to pop up VI's where I can change values. When I close the VI that popped up, I can select another VI to open if I choose to edit the values associated with that VI.
My problem is, the code I am using work great with two of the three VI's. The only VI that it doesnt work on is the largest in size of the three... around 900KB. All the code to open vi reference is shared, so everything is exactly the same. I've checked the spelling and stupid errors at least 10 times over, so I was starting to wonder if the file size affected anything. Thought maybe if the file was too large that it couldn't be opened.
Any thoughts?
Matt
(2,614 Views)
Nevermind Smiley Mad ... the name I was sending to the Open VI reference must have had an extra space.... making it extra hard to spot, considering all the spellings were correct.... GRR.... its always something stupid.
Mods can delete this thread, so that I may retain some dignity. Smiley Indifferent
(2,603 Views)
