Open Folder to Browse (aka, Open windows explorer to known folder)
Hi guys,
This must be pretty trivial, but I can't find a way to do it.
I just want to add a button on my vi, which opens up a folder to browse at a known path.
So lets say I generate reports into the following folder, c:\Temp, I wanna click on a button and it'll open up the Temp folder for browsing as though I went Start->run->C:\Temp
(5,439 Views)
Accepted by topic author markza
Use an event structure to look for the button press. In the event use something like the following:
Ian
(5,437 Views)
Hi markza,
  For the functionality you desired with a button,you need to create an xcontrol.
Thanks and regards,
srikrishna
Srikrishna
(5,431 Views)
Thanks Ian, should've thought of that, works like a charm.
(5,424 Views)
Capture the button press & place the "File I/O>>Advanced File Functions>>File Dialog" in that event case. Wire the desired path as the start path.
(5,410 Views)
No, Ian got it right hence why I marked this as solved a few hours ago.
I dont want to get a path to a folder to use in Labview (if so I would have use a file dialog like you suggested), I wanted to purely open a folder in Wnidows as though I'm using explorer - thanks Ian.
(5,406 Views)
