04-08-2016 08:23 PM
I am reading a barcode and based on which bars are present, I want to assign a value. I have set up nested case-structures to assign values for each of the possible set-ups of bars that are present. Now i am trying to figure out a way to only output the value of the one case that is true. Is there any way to do this?
04-08-2016 09:05 PM
It would help your cause if you showed us your code. But it sounds like you do not need nested case structures. You can have a number or a string be used for the case selector and you can have a lot more than 2 cases for a single case structure.
