One time Message in While Loop
I'm trying to have a message appear only once when a boolean switch is turned on. The switch is in a While loop that controls instruments. Is my approach (see attachment) the best one or is there a simpler way?
The code is in Labview 7.1
Steve
(3,174 Views)
Change the mechanical action of the switch to Latch when Pressed. Then you can simplify as shown in the attached vi.
- tbob
Inventor of the WORM Global
(3,173 Views)
The "Read a Message" button also turns on the instrument in the frame. Is there a way to keep the switch on and have a one time message tell the operator to "set the voltage" but not have so much code. I've modified the VI to better explain what I want it to do.
(3,158 Views)
Something like this? Its just a round about idea using shift registers...
Didnt include the loop for the instrument control for clarity.
(3,152 Views)
Mrr... editing a message would be a nice feature
(3,149 Views)
