One Button Dialog - Stupid Questoin
I did a stupid thing.  I put a one button dialog in one of my VIs that Pop-Ups with the word "test".  Test was a poor choice of words, because that string exists like a million times in my program.  Usually, I include a call trace string in by debugging pop-ups, you know... so i don't loose them..
Is there a way to find all the VI's the call the One Button Dialog?  If I recall, it's not really a VI, but a yellow/orange function.  For the life of me, I'm not seeing it in dependencies (which if it's a function and not a VI... ).  I'm slowly going crazy looking at all the instances of the word "test".  I'm hoping it's searchable in dependencies, and I'm just missing it.
Am I missing something?  If nothing else, have a good laugh at my expense 🙂
(418 Views)
Accepted by topic author wldgoose
To find all instances of an object (primitive function or subVI) in all diagrams of your project:
1. Open your top-level VI(s) (this allows to load the entire call hierarchy).
2. Press Ctrl+F.
3. Search for: "Objects".
4. Application Instance: usually "<your_project>/My Computer".
5. Select Object: <your_object> (example: Functions > Dialog and User Interface > One Btn Dialog).
6. Search Scope: <All VIs in Application Instance>.
7. Check "Ignore VIs in vi.lib".
8. Press "Find".
Raphaël.
(409 Views)
One Btn Dialog
didn't think to abbreviate
My top-level is actually very small.  Most of the application is dynamically opened (which this will miss).
Still haven't found it, but this was exactly what i was looking for..  if I can't get it w/ this, i'll do some VI scripting..  ugghhh
2. Press Ctrl+F.
8. Press "Find".
Raphaël.
(394 Views)
Ah, I should have said "Top-level VI(s) and dynamically linked VIs".
When I dynamically call VIs that are known at edit time, I usually put a static reference on the diagram next to the Open VI Reference. This forces a static linkage that loads the call hierarchy when the top-level VI is loaded, and it also auto-includes the VI in builds.
(356 Views)
I already wrote the scripting code for you. 🙂 Check out this VI Analyzer test:
Test - Find Function - NI Community
(350 Views)
In the old days there was advice to use a "Tree VI" to hold all the top level VIs and dynamic loaded VIs. The "Tree VI" may be broken and is not used anywhere, it is just to load all VI hierarchy into memory if needed and can be used to document call hierarchies and other things.
Searching for an object in a "Tree VI" should find your all your objects.
(190 Views)
Select the One Button Dialog (drop it in an empty diagram if you don't know of any), Ctrl-F and it should automatically be in Find this object mode.
Qestit Systems
Certified-LabVIEW-Developer
(178 Views)
