05-05-2015 05:13 PM - edited 05-05-2015 05:29 PM
Labview 2012, windows 7 Pro on computer A and windows 7 home on computer B.
Computer A and B are connected to the router using wifi.
IP for computer A is 192.168.1.76
IP for computer B is 192.168.1.79
Now the router is set up in a way that it publishes the webserver on computer A, i.e. when I type, 128.200.xxx.xxx:80, it directed me to the LabVIEW Web Server on computer A.
Is there a way to have the LabVIEW Web Server on computer B come into play, using the same router?
Thanks you.
-Chen
--------edit-------------
Forgot to mention that I was trying to connect from the WAN
Solved! Go to Solution.
05-05-2015 05:25 PM
What does the router have to do with anything? It seems both computers are on the same LAN, so the router just acts as a dumb bridge.
You should be able to reach any LAN computer from any other LAN computer on the same subnet. If it does not work, it might be a firewall setting on the server.
Are you also trying to connect from the public network (WAN side of router)?
05-05-2015 05:29 PM
Sorry I forgot to mention, I was trying from the WAN, thanks!
05-05-2015 05:53 PM
