Old function not found.
Hello, I am new to LabIVEW.
I'm having trouble finding the function "_browser Open Document Using DDE.vi" in the subvi created by quoting the sample vi using LabVIEW2011. I am not even in my ability to create this function. I would appreciate it if you could tell me how to find the function in this case.
(4,579 Views)
Hi Pitaro,
delete that missing function and use the "sysexec" way as is already implemented!
(4,551 Views)
Dear Mr. GerdW
Thank you so much for your instruction.
But I don't know where "sysexec" is or how to use it.
Please let me know.
Best regards.
PITARO
(4,543 Views)
Hi Pitaro,
It's already implemented and visible in your own image: there's a comment "DDE failed, use sysexec"…
(4,533 Views)
What he meant was to just remove the missing function and the error case structure, as the sysexec (the gray box with the >>_ symbol) should already be working.
(4,530 Views)
Accepted by topic author PITARO
There is also a function in the function palette that is doing the similar operation.
Programming->Dialog and User Interface->Help->Open URL in Default Browser.vi
Rolf Kalbermatter  My Blog
(4,501 Views)
Dear all
Thank you everyone for your advice.
Your advice didn't completely solve my problem, but I was able to find a new function in the library. I'll try this out and see if it works for a while.
I am very grateful to you.
Best regards.
PITARO
(4,446 Views)
