Office toolkit errors when upgrading to LV17
I am moving a working VI from an outdated LV13/SCXI platform to a LV17/cDAQ platform.  I am getting errors when the office toolkit tries to run the attached code. The error -2147352573, missing member occurs at the second Easy Table vi .
(2,525 Views)
Do you have Microsoft Office installed on the new platform?  I would doubt it because I don' think a cDAQ could install it.
(2,513 Views)
The LV13 system has Office 10, the LV17 system has Office 13.
(2,508 Views)
The change in office version can often cause problems because Microsoft loves to change the underlying activeX calls every version.
All I can say is dig deeper into those Report Generation subVI's and see what is causing the error.
(2,501 Views)
Accepted by topic author do-loop
Turns out it was Excel that was causing the problem. A blank workbook in Office 2003 has 3 empty sheets.  A blank workbook in Office 2010 has only 1 blank sheet.  Easy Table.vi was trying to insert a table into sheet 2 which did not exist.  I made an Excel template with 3 blank sheets and called it with the New Report.vi and problem solved.
(2,485 Views)
