Odd Description of Some Silver Buttons
Hello X,
Did the odd descriptions for the Description and Tip start upon installation or have you been using LabVIEW 2013 SP1 for some time and this just started?
If this just started, what changed between first installation and when the problem started occuring?
Best,
L.Davis
Message 11 of 15
(987 Views)
I have been using it since it was released.
The only thing I could suspect is my editing of the ini file to rearrance the projects showing up in the GSW, but I used Notepad for that and no funky characters was added (that's assuming the ini file could have anything to do with it).
I have installed and uninstalled a few packages using VIPM but nothing out of the ordinary.
Since it is limited to the silver palette, I hoped that could suggest some reason for the corruption.
Message 12 of 15
(972 Views)
Rename your .ini file to something else.  When LabVIEW can't find it upon opening, it should create a new one.
Close out and restart LabVIEW to see if you still have a problem.  (Later you can delete and restore your original .ini file if it turns out that wasn't the problem.)
Message 13 of 15
(961 Views)
Nope. Not an ini file problem after all.
Message 14 of 15
(925 Views)
Hmm. I wonder whether this could be the G# toolkit I installed?
I struggled for a while to understand why my conpane defaulted to some weird pattern and no modification of the ini file would solve the problem, until I found out that G# was overriding that ini setting.
Anyone with G# installed noticed the weird silver control Description?
Message 15 of 15
(908 Views)
