Octave analysis (Algorithm)
Hi Andy,
I agree with you with the points that you talked about,  but if i use the power spectrum  i am calculating the g RMS  values for my power spectrum vector. but for me i am looking only for the peak g level.
Secondly, i am in that example analysing the signal in only one impulse and i think the values are quite near to be real !
on the other hand, that   the FFT generally it split our time signal into a sum of a sinewave so i think that i need to make the sum of my spike's magnitude only of each band and not the sum of all the vector's band ?! it seems to me like i am calculating the energy if i do only a sum square but not the g level!
Thank you again for helping me
Best Regards
Message 21 of 25
(2,331 Views)
I'm afraid I'm not quite sure what you're asking here.  The peak level in any band is sqrt(2) times the RMS level.
Attached is a modified version of my earlier example showing the calculation of 1/3-octave band levels using filters and using the FFT autopower.  The signal contains two sine waves with amplitiudes 1 and 2.  Both methods give RMS band levels of 0.707 and 1.414 as expected (multiply by sqrt(2) to get original amplitudes).  I hope this makes things more clear.
Andy
Message 22 of 25
(2,308 Views)
Hi Andy,
Could you please make it on an old version because i am using a 2012 LabView version
Thank you
Message 23 of 25
(2,302 Views)
Accepted by topic author virtman
I saved this for version 12.0.  See if it works for you.
Andy
Message 24 of 25
(2,297 Views)
Great Job of explaining a complex subject in easy to understand description.
Message 25 of 25
(2,259 Views)
