Obtaining the IP Address of a NIC
I want to communicate to an Ether I/O 24 device over UDP.  I am using a DHCP server to automatically give me an IP address for it.  How can I get the IP address of this device in LabVIEW 8.6?  I have done some searching and I can't seem to find exaclty what I want.  The VB .exe that came with the device has a function called scan for modules and it returns the IP address with the MAC address.  The PC I am using has two NICs and the module is on subnet 255.255.0.0
Any help appreciated.
(2,805 Views)
This is usually done by proprietary UDP broadcasts to the devices which recognize the specific packet format and answer with a packet that specifies their own IP address and other information. There is no generic way to find out the IP address of a network device.
Rolf Kalbermatter  My Blog
(2,778 Views)
I assume this is the subnet mask, not the subnet address.
I would use wireshark and do a packet capture when running the VB.exe. See if you can duplicate the communication in LabVIEW later.
(2,767 Views)
