Obtaining list of Teststand variable names from labview
Hi all
I'm trying to generate a list of TestStand variable names from Labview, based on some example code I found in the Dev zone http://sine.ni.com/devzone/cda/epd/p/id/3086 but running into trouble. I was expecting the routine to output a complete name, but it only returns the first part, for example
StationGlobals.TS
and not
StationGlobals.TS.LastUserName
StationGlobals.TS.CurrentUser.LoginName
StationGlobals.TS.CurrentUser.Password
etc
I've managed to retrieve these using extra loops, but since there could be any number of subproperties in a variable name, it suggests the routine needs to be recursive, and that's where I come unstuck.
Is there anyway of doing this without using recursion?
Bruce
(2,765 Views)
There's not a whole lot of people in this forum who use TestStand, so you might have better luck with this in the TestStand forum. If you post there, please indicate in this thread that you've moved the discussion so people don't get confused as to where to answer, or provide duplicate responses.
(2,760 Views)
Sorry, I've not worded my question very well. I was really looking for advice on implementing a recursive routine in Labview, that interrogated TestStand, and just assumed it was more relevant  to this forum. If not, then I'll re-post elsewhere.
Bruce
(2,729 Views)
