Objheap.c error in LabView 5.1
Recently, I have trouble in compiling my .vi files to build an application (like .exe files). The error message I have is:
Failure: "Objheap.c"
Line 473
Labview 5.1.1
I know that might be due to the code corruption based on the research result from NI site research result.
My question is how to fix that without impact to my .vi code.
Many thanks,
(2,725 Views)
Hi Maserati,
Are you using LabVIEW 5.1 or is that just part of the error?  If you are using LV 5.1 it is going to be difficult to find the problem since that is more than 4 versions back.
Not being able to change the code will also make it hard to siphon down the problem.  I would suggest removing code to see if it is linked to a certain portion, but if that is not possible I am not sure how to proceed.
Brian K.
(2,710 Views)
