OPCUA Read in Parallel
Background: I have two S7 PLCs that are connected in LAN from which I request to read data from LabVIEW using OPC UA toolkit. I could read the data correctly
Problem: I created preallocated clones of "Multiple Read" VI and tried to read them simultaneously. However when I check the communication with wireshark, it appears to be serial wherein the second request reaches the PLC only after first request is answered. I am unsure if I am actually making the request in parallel.
The LabVIEW PC's IP is 192.168.0.30 The PLCs end with 10 and 20
Message 1 of 1
(1,103 Views)
