OPC version of Eurotherm iTools, How the Eurotherm 2604 can be controlled with Datasocket connections
Hi All,
As I got some of old postings about using OPC for interfacing Eurotherm 2604 in LabVIEW. I believe there may be lot of ways to do that. If some body can help to post some examples, that would be great help.
Thanks.
(4,292 Views)
Just make sure that the 2604 is set-up and working from the Eurotherm Modbus server.  You can then create controls and indicators in Labview and connect them to items on the 2604 using Datasocket connections.  I have an application that has been running this way for several years without any problems.  By the way, custom instruments can be created in the modbus server.  This is one way to communicate with almost any instrument to OPC.  Create a virtual instrument in the Eurotherm modbus server, create a VI that communicates with the actual instrument, then link the two using Datasocket.  You now have an instrument that can be accessed by any OPC client.
(4,288 Views)
Thanks Brian,
Let me try with your suggestion.
Thanks and Regards,
ii
(4,277 Views)
