OPC example to control instrument
I have an HV power supply from ISEG for which I need to write a VI to be able to control and monitor each individual channel (32 in total). The communication happens with an OPC server and I should point out that we do not have the LabVIEW DSC module .
So far, I have managed to talk with the instrument and bind the controls and indicators on my VI to one HV channel. I also made a VI which programactically changes the URL to bind the indicators to a different channel, when executed. So I guess I can do all I need. However, the overall code is sloppy and not very flexible so I am looking for an example of how to write a nice piece of code.
Ideally, what I want is a front panel with a quick overview of all the channels (status, on/off, current voltage) and some additional panels which can be opened with a button to view more details for each channel. I realize this request is rather vague but any help and suggestion (even in terms of "look chapter X of book Y") would be greatly appreciated.
As an additional question, I am still a bit confused about the data binding for controls. Sometimes you can have a LabVIEW control which acts as both reader and writer to the corresponding OPC value and this makes me feel a bit unease. What is the "good etiquette" for using front panel elements and data binding?
Cheers,
Paolo
(2,716 Views)
Hi Paolo,
are you using datasocket in order to communicate with OPC?
Datasocket is an alternative communication method withou using DSC Module.
This is a good tutorial that will help you. Here instead you can find how connect LabVIEW to OPC with datasocket.
Best Regards
Cla_CUP
(2,689 Views)
Hi Cla_Cup,
thanks for your reply.
As I wrote, I can communicate with the server. I use both datasockets and control data binding. However, my code looks really really bad and I was hoping to find some style guide on how to setup an OPC VI.
Thanks for the links.
Paolo
(2,669 Views)
