OPC client in labview doesn't work... !
Hi everybody,
I have some trouble with the opc client in labview through I/O server , when I am adding a variable (or just want to view items) , I am connecting correctly to my opc server but my opc server tell me that :
access path empty and no ! found into the item definition ( API47)!! "
 and after the labview opc client try to create a group but if I want to add an other item, he create an other group (try to...) . but that's funny because I still can see all my items in the browser and if I add this item to my library, launch my VI , nothing happend ....
I have tried to know if my opc server is working and it's work... !  the NI opc quick client (.exe) is working great , I have no trouble with that but when I am working on labview nothing works...
I have tried a opc VI that create an opc client with DSC module but I always have the same problem....
to resume : No trouble with the OPC server
                  No trouble with other opc client ( NI opc quick client , opc client from other constructor)
please can someone help me  ?!!!
Regards
thank you in advance
Marc
(2,964 Views)
Hi Marc,
OPC allways gives issues, but I've learned in the past that it's not allways LabVIEW.  It can be Windows as well.
Here is a document I once found and solved some problems I had.  It's about DCOM settings.
I don't know whether you checked these already.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(2,933 Views)
