取消
显示结果
搜索替代
您的意思是:
OPC browsing problem between Labview OPC client and remote Matrikon OPC simulation server
Hi All
I have OPC browsing problem between Labview OPC client and remote Matrikon OPC simulation server.
I have configured Labview I/O server (OPC client) in another computer and Matrikon OPC simulation server (v. 1.2.4.1) in another. The computers are located in different VLAN’s. Computers can ping to each other. I have Labview 8.5 with DSC.
I get error “-2147024891 occurred at GetOPCServerList.vi “ when I try to open properties page of I/O server.
Does anybody know why I get error “-2147024891 occurred at GetOPCServerList.vi “ when I try to open property page of I/O server ?
Please see attached zip file which includes more information with pictures about problem.
I have checked the following links but they did not help me.
http://digital.ni.com/public.nsf/websearch/231CAF98ED830635862570C200565116?OpenDocument
http://forums.ni.com/ni/board/message?board.id=170&message.id=221990&query.id=54338
Thanks.
0 项奖励
1 条消息(共 2 条)
5,510 次查看
This is kind of an old post, but is a common issue that will come up for more users: DCOM communications
Just being able to ping between the computers is not enough.  In order for the two computers to communicate, you'll need:
-No firewalls (windows included) between the two
-To be on the same windows domain (or alternatively, on the same workgroup)
-Correctly configured DCOM settings.
Set your DCOM according to vendor recommendations, or if there are none available, according to this general guideline: http://www.matrikonopc.com/support/docs/MatrikonOPC-Windows-XPSP2-2003SP1-DCOM-Configuration.pdf
Adriel Michaud
MatrikonOPC
0 项奖励
2 条消息(共 2 条)
4,071 次查看
