OPC Server how many devices at once?
I currently use a OPC Server 2016 with a "1 simultaneous driver" license. It works perfectly fine with a Siemens SPS.
Now I would like to add a second Siemens SPS to the server.
So its the same "driver" as the already connected SPS, even the same device, just with a different IP-adresse.
So does "1 simultaneous driver" mean, only one device at once?
Thanks and best regards,
afuchs_AB
(2,472 Views)
Accepted by topic author afuchs_AB
N devices as long as they all use the same driver.
https://www.ni.com/en/support/documentation/supplemental/18/1-simultaneous-vs--unlimited-simultaneou...
(2,404 Views)
Thanks Matt!
Just tested it and it works perfectly fine.
Cheers!
(2,371 Views)
