OPC Connection
I have a significant problem with connect an OPC Server to my Labview Application. I make use of  the AX OPC Server of Phoenix Contact this is already working. Now I have no idea how I can simply write a boolean or read one. I need an easy VI were I can add the IP adress of my server or something like that.  It would be nice if I can use this variable as a normal one in my VI.
I would be thankfull for each support!!!
Thank you
(2,945 Views)
HI,
did you already open the example OPC project in the LV example finder?
Is this any help?
Anna
Anna Vogl
Certified LabVIEW Developer
(2,887 Views)
Thanks, yesterday I found a good example which helps me to find a conclusion.
(2,837 Views)
