OLE Automation Methods for Acrobat Reader in ActiveX Control
Hi, JackDunaway.
Did you finally manage to do it? What I need is similar than this. I want a PDF preview control on my FP, and I need to remove several items and toolbars from the PDF viewer window. I saw this is possible to do using several functions of the CAcroApp class, but I cannot manage to use this... I mean, taking a constant (like you showed in your picture) I get all the methods for the CAcroApp class, but how do I relate it with the ActiveX PDF preview control I have on my FP?
On the other side, I want also to disable the Run-Time menu contained on the PDF preview control. It appears when I right-click the control, and has many posibilities I don't want the user of my application to be able to access...
Francisco
Message 11 of 12
(2,906 Views)
The project was scrapped when it became clear the cost to develop would overcome the benefit. Hope it works better for you.
Message 12 of 12
(2,891 Views)
