OFDM with NI RFSG and RFSA
Hi
Does someone has any sample vi to implement OFDM using PXI. We had a sample RF front end in NI PXI. We want to incorporate OFDM modulation, scrambling-descrambling, convolution encoding-decoding. If there is any sample example to anyone it will be helpful.
Attach is the RF front end.
Regards
Farooqui
Message 1 of 10
(4,264 Views)
Maybe you could start with the Baseband Developer's Kit ?
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 2 of 10
(4,223 Views)
Hi Farooqui,
Which RFSG/RFSA hardware are you using?  There aren't any public OFDM examples for RFSA/RFSG to my knowledge, however we do have a couple for multiple USRP devices here and here.  I would take a look through those for the code structure and adapt it by replacing the USRP specific VIs, as a potential starting point.
Message 3 of 10
(4,213 Views)
PXI 5610,5421,6653
Message 4 of 10
(4,200 Views)
Hi Farooqui,
Here is another example that might be useful.  It is just a software example using the Modulation Toolkit.  You would need to had the appropriate RFSA calls.
RF Simulation Demo: OFDM
http://www.ni.com/example/30152/en/
Hopefully this is helpful!
Josh B
Message 5 of 10
(4,181 Views)
yes, i already downloaded this VIs and trying to understand 🙂
Message 6 of 10
(4,176 Views)
Hi Matt_L
i am waiting for your feedback.
regards
Farooqui
Message 7 of 10
(4,155 Views)
Hello Alfarooqui,
Matt_L is not in the office at the moment - but from this thread, it is not clear what feedback you are still needing.
Matt_L, Josh-B and GovBob have all provided links to potentially helpful resources.  Did you have a specific question about one of those resources?
Cheers
Matthew H.
Message 8 of 10
(4,141 Views)
Hi
According to Matt_L last feedback
" I would take a look through those for the code structure and adapt it by replacing the USRP specific VIs, as a potential starting point."
So i was talking about this.
Regards
Farooqui
Message 9 of 10
(4,136 Views)
Hello alfarooqui,
I believe this may be a translation issue, Matt_L was recommending that you attempt to make these modifications.  A subtle difference of "I would" and "I will", but the meaning is quite different.  I don't believe he is working on adapting the linked examples at this time.
That said, I believe this is already available as a feature of multiple NI Wireless Toolkits or toolkit packages.  Have you attempted to use the example linked by Joshua-B?
Best Regards,
Tom L.
Message 10 of 10
(4,128 Views)
