Numerical indicator with spaces between each group of 3 digits AFTER the decimal separator.
I would like to display the numbers in a numerical indicator with a space between each group of 3 digits AFTER the decimal separator. How to do that?
(4,038 Views)
You need to use a plain string indicator and do your own formatting of the numeric data, shouldn't be too hard. ;).
You can also make an Xcontrol.
(4,030 Views)
I don't think that it is possible to display a number with that format in a numeric indicator.
You could convert the number to a string indicator:
1.) Find the number of decimal places required
2.) Convert the number to a fractional string with the required number of digits
3.) Use the match pattern and string subset functions to build your string
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(4,027 Views)
Thanks. Problem solved.
(4,017 Views)
Something like that for example...But you can modify this VI to determine automatically how many decimals are necessary after the decimal separator.
(4,004 Views)
Oups, be careful : my VI doesn't work so much in some cases ! But anyway, if you have found a solution by yourself that's OK...
(4,001 Views)
