Numerical Classification
Case 1 can be solved like this:
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 19
(1,795 Views)
Your expected grouping output file cannot be correct, because the first row contains duplicates (32, 56, 73).
Here's a quick draft solution that gives the same output (once we remove the duplicates in your grouping file and sort each row!)
As suggested, I uses a MAP where the key is the output row and the value is a SET of positive integers. The output rows are naturally sorted.
(Just a rough draft. I am sure it can be simplified! There could also be bugs)
Message 12 of 19
(1,766 Views)
Thank you.
It seems I can't open it in my LabVIEW 2018 environment.
Is there a way to open it in 2018?
mxarai
Message 13 of 19
(1,746 Views)
No. SETs and MAPs were introduced in LabVIEW 2019. Rewriting it in traditional code would be tedious, but could be done.
See also my talk.
Message 14 of 19
(1,733 Views)
Everyone,
This task seems extremely difficult to code in LabVIEW 2018, so I've decided to give up and do it manually.
Thank you all for your cooperation up to this point.
mxarai
Message 15 of 19
(1,657 Views)
You can replace the maps and sets with variant attributes as explained in my talk. Should be very quick.
personally, I would use an array of clusters where each element is a row.
Message 16 of 19
(1,629 Views)
Here's a quick draft that does not use anything fancy (maps, sets, variant attributes)
LabVIEW 2018). I am sure it could be simplified further.
(See below for a simpler version)
Message 17 of 19
(1,618 Views)
Accepted by topic author mxarai
OK, I simplified it a little bit over breakfast. Same result, but please test.
Message 18 of 19
(1,605 Views)
Hi altenbach;
This is excellent.
I was able to confirm the results I was hoping for.
Since I needed to verify this process multiple times, this was a huge help.
Thank you very much.
I appreciate it.
mxarai
Message 19 of 19
(1,592 Views)
