Numeric variable in Labview 5.1
Is it possible to use a variable in an equation, then put another value
in the variable, and then using the variable again in the equation?
tia,
bull's
(3,064 Views)
you just have to organize your equation into subVI and connect your variables to its input and output nodes. So each time you call this subVI you can pass there new values of input variables.
Good luck.
Oleg Chutko.
(3,064 Views)
