Numeric time format
Hello everyone,
I am new to LabVIEW. I recently wrote a LabVIEW block diagram that is used to collect data from 3 different sensors which are connected to the same DAQ. My block diagram outputs the data into a spread sheet. The issue I have is that the time column contains the time in the following format (00:00:00:00). All the values in the column are in the same format with a 0.01 seconds difference from the previous values. I'd like the output to my time data column in the spreadsheet at least in a numeric form (0, 0.01, 0.02, 0.03, etc) while sticking with the waveform.
Is that possible and how to do so?
Thank you and regards
(2,936 Views)
If course it's possible. What are you using to write to file now?
(2,922 Views)
I'm using "Export waveform to spreadsheet"
(2,918 Views)
Write to Measurement File uses relative time if I recall. Write to Spreadsheet File, you can use any format you want but you have to write the code yourself. You can create an array with just the dt and a shift register inside a for loop.
(2,910 Views)
