Numeric indicator with LED
I have a numeric control and a rectangular LED that changes colour from Green>Yellow>Red with different range of values for each colour. I was wondering If I can place this LED behind a numeric indicator. Basically have the background have the LEd while the number displays the Numbers in the front. I tried to change the order of these items but doesn't work the way i want it to.
Any help would be great! Much appreciated!
Thuba25
Message 1 of 11
(5,878 Views)
You can overlay and arrange objects on the z-axis -- however it is not recommended due to potential performance issues.
How about rather than having an LED behind the control, change the background (or perhaps text) color of the control itself?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(5,874 Views)
This is the best attempt I could do... I set the background of the Control to transparent using a Property Node:
EDIT:
it should also be noted i used "Bring to Front" on the Numeric Control.  I also disabled the label and increment/decrement visibility:
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 3 of 11
(5,865 Views)
Ooh, Ooh, Ooh...
Mr Happy's suggestion just gave me another idea: Have nothing but the LED and display the number in the LED's Boolean Text property.
Mike...
LabVIEW Champion
Message 4 of 11
(5,860 Views)
@mikeporter wrote:
Ooh, Ooh, Ooh...
Mike...
I like this idea even more than mine.  It would look much nicer.  But I dont have time to create another example if you would like to do the honors.
Message 5 of 11
(5,856 Views)
How can i do that ?
Message 6 of 11
(5,850 Views)
Thuba should be able to comeup with the code, there's property nodes for all the significant bits -- as well as examples that ship with NI.
One hint though: The Boolean Text for an LED typically isn't shown by default, you'll have to turn it on manually.
Mike...
LabVIEW Champion
Message 7 of 11
(5,848 Views)
I don't want the text to be just two values for ON and OFF. The colours will be green yellow and red. So i would like to display the range of numbers, lets say 1-10 for GREEN , 11-20 YELLOW and 21-30 RED.
Message 8 of 11
(5,846 Views)
That's fine, there's also a property node for what the boolean text should be, and for three colors vary the button color using property nodes -- rather than the boolean value.
Mike...
LabVIEW Champion
Message 9 of 11
(5,843 Views)
Thats why mikeporter's recommendation was even better.  You can literally set the string "1-10" or an individual number "1" using a property node.  See here for an example of property node's changing the label: http://digital.ni.com/public.nsf/allkb/35994A10267179A286256E15006D4255
Message 10 of 11
(5,842 Views)
