Numeric control showing weird value
I am facing something weird
When I enter some number into one of my controls it shows HEX values (if I am correct). This happens only when I insert negative values. Any idea why is that ?
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(2,399 Views)
Accepted by topic author abikutn
Right click your control, select Display Format... and select decimal (it is probably set to hexadecimal right now).
Ben64
(2,385 Views)
