Numeric control not retrieve the previous Value?
     I am facing one problem in numeric controller,i,e i have set the Max and minimum value in coerce mode..
for instance, maximum value is 10 and minimum is 0.In run mode it wont allow the value beyond this limit,suppose currently i have the value "5",if i change the value which is maximum of limit consider i put the value now 15
it automatically change 10(maximum limit) not to retrive the previous value "5"...
if anything possible to retrive the previous value when user enter value  beyond the maximum limit in numeric control?
pls give the solution?
Raj
(3,789 Views)
You can do that using event structures. Have a look at the image below.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,784 Views)
thanks for your replay...
is this only possible in coding? not any default labview settings?
Raj
(3,767 Views)
That is the only way to do it.
(3,764 Views)
More generally, like this:
(3,727 Views)
hi pcardinale thanks for ur replay,
you have done effectivly but in your case two things we need to do,
1.if we need maximum value 5 ,we should set maximum value 6,other wise we cant realize the value which is beyond the limit.
2.if weneed miminmum value 2,we should set 1,
i just gives my sugesstion  ....thanks
Raj
(3,707 Views)
Try right clicking the in range and coerce function and select Include Upper Limit.    That will make the upper diamond black and the upper limit will be considered in range.
Compare Adnan's picture to pcardinale's.
(3,705 Views)
