Numeration of probes
Hello everyone,
I am currently debugging my project using Probes and Break Points. I have set many probes, but sometimes I forget some in a VI. The new probe is now on the bottom of the list in the probemonitor. This is often very confusing, since it may be called before the other probes.
My question: Is it possible to change the enumeration of the probes?
(1,969 Views)
No way that I am aware of.
I do know that probes are grouped by VI.  So a new probe in the VI should be a the bottom of its group, not the bottom of the entire window.
(1,936 Views)
They are grouped, yes. But in the group it is still confusing when it is on the bottom.
Maybe I can add it to the wishlist
(1,931 Views)
There are two ways (related) to renumber probes.
  1. Close the Probe Window and dismiss all the Probes.  Then re-create them in the order you wish them to appear in the list.  The "down-side" is that the numbering will not reset, so if you originally had 11 probes and closed them all, the next Probe would be #12.
  2. Stop, then restart, LabVIEW.  This is similar to Step #1, but now the Probe numbering will restart from 1.
Personally, I find that having more than 4 or 5 probes open at a time is confusing.  My approach is to put several in "critical locations" -- if everything passes, I close the Probe Window and place a new set "at the next place to check".  If I'm trying to do a "wide-spread Fishing Expedition", I restart LabVIEW and try to place the Probes in the order I expect them to be activated.
(1,923 Views)
