Numbers to boolean-operator question
http://img255.imageshack.us/my.php?image=numwired2booleanopag0.jpg
I have no idea what this code does. Can someone explain this to me?
Message Edited by Heinen on 12-18-2008 02:20 AM
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
(2,807 Views)
Accepted by topic author SectorEffector
just a or gate, ex (3 or 5) #  (011 or 101) = 111 = 7.
about utility  i knew that when i was young  :smileyhappy:
may be with network , today i could'nt say ?
Best regards
Tinnitus
Message Edité par tinnitus le 12-18-2008 02:42 AM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,795 Views)
It is the logical OR from the boolean palette.
If you use it on integers as in your case, it will do a bitwise OR.
(You can always right-click the function and select help to get more information. Try it! :))
(2,785 Views)
