Number of rotation not match with the action inside the loop
This loop is a part of code.
A motion control should be acquired inside the loop.
This controller moves a stage by limited distances (X).
I can control the movement step through the terminal (step).
if the step is something large the loop transfer to the next rotation number (i) before the controller finishes the current movement. For example, if I set the number of rotation to be 6. the loop rotation number (i) reaches 6 whereas the controller still in the second or third movement.
my question: How can I let the loop don't transfer to the second rotation step until all the code inside the loop finish. I used timing statements like the attachment, but it not helpful in all the cases.
(1,300 Views)
Accepted by topic author BaJa_2020
Hi BaJa,
create a proper statemachine to control your device.
Send a move command, then read the current position and wait until the device has reached the target before you send the next command!
(1,261 Views)
