Number of Stacked Shift Registers based on Control
I'm using stacked shifts in my code and I would like the number of stack shifts to correspond to a number from a control. Is there a way to do this? Thanks!
(2,635 Views)
No.  Why do you need it to change?
I'd recommend using an Action Engine setup to store the data.  Have it behave as a circular array.  There you can define how many elements you want to maintain in the array before discarding old data.
(2,634 Views)
I'm trying to average numbers and doing so by using stacked shift registers in a loop. The only issue is the number of numbers being averaged is not constant and I don't want it to average the last x amount of numbers. I will look into using an Action Engine.
(2,632 Views)
Check out the Mean PtByPt.vi in the Signal processing palette.
(2,619 Views)
