Number of Arguments for "Format into String Function" is variable
Hello All,
             I'm using "Format Into String" in my code. The Number of Arguments/No. of Inputs and Format Specifiers are not fixed. The Inputs and String Format are coming from the Front Panel.
             I tried resolving the issue by using a for loop and indexing the input but it was throwing an error that the number of format specifiers is too many
(3,013 Views)
Well, show us your code and some typical example strings. Are there delimiters?
(3,012 Views)
Please find the code Image and Examples of Strings in the attached File.
(2,989 Views)
Accepted by topic author gargrahul
Hi gargraghul,
when all you do is replacing parts of strings you should use SearchAndReplace instead of FormatIntoString in the loop!
Otherwise you need to create an array of subset format strings as you supply an array of string arguments...
(2,965 Views)
I resolved the issue by using the search replace function and for loop. Thanks for your suggestions.
(2,950 Views)
