Number interpolation..
My input is a fractional decimal number from 1 to 20000. The output can be either 100, 200,400,800. The output should be selected according to the  princeple: For output choose the nearest  of the 4 intergers to the input number. If for example the input value will be 150   then the biggest nearest number will be selected 200.     Example ;
In   Out
1      100
250   200
300   400
2000  800
I have an idea to write a formula node for the solution. But before that I wanted to see maybe there is a nice way to use just LV to solve this problem. I am not asking for code  just for ideas. But code will be nice too. Smiley Happy
Thanks.
(3,236 Views)
Here's one possibility (if two are the same distance, it will pick the lower one, e.g. 300->200).
It finds the element with the lowests absolute difference to the input. Modify as needed.
(The "interpolate 1D" function from the math palette also has a "Nearest" method)
Message Edited by altenbach on 06-30-2008 04:32 PM
(3,231 Views)
Seems to work...
Ahhh... you beat me to it altenbach... (I'm pretty chuffed your solution is almost identical to mine though 😉
Message Edited by Troy K on 07-01-2008 09:58 AM
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(3,223 Views)
See, that's what happens if you waste your time with annotations and such. 😄
RSibagatullin, if you want to always round up if there are two choices, just reverse the array.
(3,201 Views)
Doh! Why didn't I think of that... "much to learn (I) still have".
(3,197 Views)
