Number format string
Hi to all. I have a question about formatString property when it form a number on indicator or "FormatToString" function.
How can I known the number lenght in simbols by it format string? In some cases it's easy: "%10d" - 10 symbols, but how it works in more complex cases, like "%010_7f" or "%f" or "%g"?
And how calculate symbols after point by formatString?
Message 1 of 8
(4,901 Views)
Hi Forest,
use StringLength after the FormatString function!
(Most often FormatIntoString results in a variable amount of chars…)
Message 2 of 8
(4,899 Views)
@GerdWuse StringLength after...
I want to know it before the function is done.
Message 3 of 8
(4,877 Views)
Hi Forest,
then you need to analyze your data - it is much easier to check after the conversion to string…
Example:
- value of 1 with a format of %g gets converted to "1.000000" (8 chars)
- value of 1 with a format of %#g gets converted to "1" (1 char)
- value of 1 with a format of %#3g gets converted to "  1" (3 chars)
- value of 1.001 with a format of %#3g gets converted to "1.001" (5 chars)
It is much easier to check string length after conversion than to analyze all possible input data with all possible format strings…
Message 4 of 8
(4,868 Views)
Not is it just easier, but a lot of the analysis would require at least most, if not all, of the conversion already.  So you might as well check it after the conversion and make your like A LOT simpler.
Message 5 of 8
(4,849 Views)
Number of desimal points I calculate like this:
And its work in many cases.
Message 6 of 8
(4,840 Views)
@0Forest0 wrote:
Number of decimal points I calculate like this:
So you convert two strings into numbers to figure out the decimal length.  Again, that seems wasteful.  Just convert the original number and use Search/Split String and String Length to get your decimal length.
Message 7 of 8
(4,825 Views)
When I prepare long string of values I don't know what values (big or not) will convert to string. But I shall put numbers on exactly positions in result string. Then I should know lenght of result string basing on formats of containing values.
Message 8 of 8
(4,814 Views)
