Notifier
@Ben wrote:
Have you considered wrapping the notifier action in an Action Engine that is served via VI Server?
While I have not done it with notifiers I have exposed queues on one machine to another by wrapping the Queue operations in a AE that was served. Aside from a bug in LV 6i-RT tht would kill the queue if the connection was closed, that type of operation has been around for a long time and works well.
Ben
Ben
Can you give me an example code of how you did this through AE?
I have not used AE.
Ben
Ben
I have not used AE.
Can you please share an example code you have done that uses this method?
Sable
Message 11 of 12
(941 Views)
Action Engine
Attached is a VI Template I use (currently in 2016).  I have other versions for queues and User Events that I use a lot more often.  The idea is that anybody sending the Notification just calls the Send task and the data is sent through the Notifier.  Anybody needing to listen for the Notification needs to Get Reference and then use the reference that is passed out to wait for the notification.
Message 12 of 12
(936 Views)
