Notifier
Hello, i am now building an application with Labview. I need to read the result data from Sub vi and I used the notifier function. But i can't read data from main Vi. Someone got an idea?
Message 1 of 12
(6,162 Views)
Use "wait on notifier" not "get notifier status". Make sure the names are exactly the same.
Message 2 of 12
(6,153 Views)
Also, please post your code. If you are very new to notifiers, there may be a better way to do what you are doing.
Message 3 of 12
(6,149 Views)
There is also the question of whether or not the Notifier is the right tool to use.  I rarely use Notifiers due to their lossy nature (of you write to the Notifier twice before the read gets around to it, you will not get the first notification).  So I typically use Queues or User Events.
Message 4 of 12
(6,127 Views)
You might also find this information useful:
http://www.notatamelion.com/2014/10/07/build-a-proper-labview-produceconsumer-pattern/
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 12
(6,071 Views)
Hi Mike,
have you written the follow-up post that you tease about at the end? I make heavy use of queues in most of my data acquisition applications, and I'm wondering where you're going with it!
Message 6 of 12
(6,020 Views)
Yes, keep reading the subsequent posts.
Mike...
LabVIEW Champion
Message 7 of 12
(6,009 Views)
Alrighty, I have not explored the Teststand project too much because I still have not gotten my tortoise svn to play nicely with your repository 😞
Message 8 of 12
(5,999 Views)
It's not teststand, it's LabVIEW. What is the issue? Did you register?
Mike...
LabVIEW Champion
Message 9 of 12
(5,976 Views)
Sorry, I meant the Testbed Application, and I just typed the first test-word that came to mind! I did register for the website (I was never prompted for a password when accessing the repository). My attempt is explained in this comment:
http://www.notatamelion.com/2015/03/02/building-a-proper-labview-state-machine-design-pattern-pt-2/#...
Message 10 of 12
(5,969 Views)
