07-12-2007 08:37 AM
Has anyone seen these errors and know what it could cause it? I don't have the application on had to test but it is necessarilly repeatable. Occurred after the application was running for a number of hours.
A dialog window with the following information:
Unspecified error occurred.
VI “RecipeStep.vi” was stopped at node 0x0 of subvi “DAQmx Clear Task.vi:1”
This was procedded with another error that would not allow any operation to occur to the machine.
Not enough quota is available to process this command,
07-12-2007 09:15 AM
07-12-2007 09:21 AM
It is a cycle test fixture that moves a couple Linmots using serial commands, tests communication with the fixtures Aux and IP ports (pings and writes serial command for response), and turns some IO on and off using NI IO card.
No external routines have been introduced to program. Using Labview 8 Advanced Serial VI and Ping VI.
Thanks!
07-12-2007 09:57 AM - edited 07-12-2007 09:57 AM
Message Edited by pincpanter on 07-12-2007 04:58 PM
Message Edited by pincpanter on 07-12-2007 05:01 PM
07-12-2007 10:22 AM
07-12-2007 10:29 AM
07-12-2007 10:31 AM
07-12-2007 10:35 AM
07-12-2007 10:41 AM
07-12-2007 10:48 AM
I'll look into both.
Thanks!
