Not enough memory to complete this operation - property node - chart
I need to plot 4 variables continually. So , I decided to use Charts.
But I want to implement some functions to this chart, for example, change the plots names, set visible or not, change the color...
So I decided to use property node to do this.
But when I call the property node (by event structure or inside the loop) appears the error: "not enough memory to complete this operation".
Does anyone knows how to solve this problem?
Thank you very much
(3,702 Views)
Do you need to do this programmatically or from user inputs?  You can how the legend and the plot visibility checkboxes to allow the user to do all of this.
(3,677 Views)
I need to do this programmatically.
(3,665 Views)
(3,599 Views)
Post your code. I am.suspicious that there is a programming/math error at fault.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,589 Views)
