Not case sensitive string comparison
Is there any chance that the coparison function below returns true value?
Message 1 of 23
(11,907 Views)
I can not find a way to make it equal without the force to capital.
Tim
GHSP
Message 2 of 23
(11,900 Views)
If forcing 'To Upper Case' or 'To Lower Case' as Tim suggests isn't good enough, then one option is that Search and Replace string allows case to be ignored when comparing strings.
Checking that there is more than zero 'replacments' and checking that both strings are the same length gives a case insensitive comparison.
Message 3 of 23
(11,867 Views)
Message 4 of 23
(11,856 Views)
Yeah,
I know that is a good idea. One of my colleaqueas built on this 'straight' comparasion a solution and now I have some
problems.
What I would need is what Philip presented. Good idea.
Cheers.
Message 5 of 23
(11,845 Views)
You can do it like this
Tim
GHSP
Message 6 of 23
(11,838 Views)
It is exactly what my colleauge did. It doesn't work for me now.
Cheers
Message 7 of 23
(11,820 Views)
 <deleted>
EDIT: Hang on... when I started that post it made sense.... now I look at it again I can't remember why it would be any better than just forcing to the same case.... brain freeze Smiley Sad Sorry ignore me!
Message 8 of 23
(11,815 Views)
What are you trying to do?
Tim
GHSP
Message 9 of 23
(11,814 Views)
Is it possible that one of your strings has a non-printing character?  Look at it with a '\' Codes or Hex Display.
Lynn
Message 10 of 23
(11,801 Views)
