Not accurate result when we decimate large array of data
Hi Everyone,
I am facing problem in handling long record lenght data. Initially i used the decimation algorithm to reduce the large record lenght from Mega Samples to Kilo Samples.But when it comes to performing calculations such as finding the mean or average of the resulting reduced record lenght waveform, I'm getting wrong answers. I think this is because of loss of information in waveform data due decimation. any body faced such problem or have a solution to such a problem please help me. Is there any solution such that i can reconstruct or resample the output decimated waveform to include more information in to the waveform such that i can get approximate results. I tried using resample VI but could not get accurate results.
Thanks in advance.
sayaf
(2,487 Views)
What do you mean by "not accurate"?
A statistical analysis should not depend on the sample size, except that the result becomes more reliable. If you get statistically different results, it means that your decimation is biased. This can for example happen if your signal contains a certain frequency component and your resampling is related to that frequency.
Example: Your data contains a strong component at the Nyquist frequency (half your sampling rate). If you would throw away every other data point you get an overestimate or underestimate (depending on the phase) if you take the mean of the resampled data.
Can you attach some example data? How do you decimate? How different are the averages as a function of sample size? Are the differences you see statistically significant?
Maybe you could add some randomization to your decimation, e.g. pick randomly one element from each consecutive 10 samples for a 1:10 decimation. If you are just interested in averages, you could also average a certain number of points to create one point in the resampled data (here you would significantly change e.g. the standard deviation, but you could still estimate the original standard deviation from the standard deviation of the resampled data and the decimation factor).
(2,481 Views)
