Not able to enter values in an array.
I am not able to enter values in any array i create in labview.By mistake i pressed some key on the keyboard and whenever i try to enter values in an array till then,  a pop up window opens and reinitializes the value to zero if i make selection from there.
i am attaching the screenshot.
(3,793 Views)
Upload your VI
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,779 Views)
I don't find anything like this before in LabVIEW,
But just to know do you have installed any other software on your PC which gives suggestions for whatever you type?
This looks like a suggestion dictionary dropdown list but is it also visible in MS word if you type anything in it just try it and let us know.
Also please mention the OS of your PC along with the LabVIEW version.
(3,778 Views)
When i am opening a new VI it is no longer there.Actually i saw someone suggesting to enter values in an array through ALT enter rather than using mouse.l did that and came accross the figure.Even , I am not able to figure out the reason
(3,767 Views)
Most likely you turned off the autotool.
(3,762 Views)
Why dont you upload your VI. It will be easy to debug
--Ranjeet
(3,760 Views)
Accepted by topic author kausreloaded
I'm with Altenbach on this one.  It sounds like you turned your Autotool off.  If you go to View->Tools Palette, you will see the Tools Palette.  Make sure the top button/LED is on.  That will make sure the Autotool in on.
(3,723 Views)
