Not a path
Watch out for this one guys, although it is easy enough to work around.
Its on 2010 and 2009, perhaps further back as well.
(3,353 Views)
Are you claiming a bug?  Or just a point out something that caught you off guard?
The results of the VI are accurate.
In the top you used a Not a Path constant, checked it for "not a path" and the result is true.
In the top you used the same constant, and converted it to a string.  The string is empty.  Converted it back to a path.  Now you do have a path, it just happens to be an empty path, so when you evaluate it for Not a Path, the result is false.
An empty path and a Not a Path are two different things.  But you lose that information when you convert it to a string datatype.
(3,350 Views)
I agree.
It actually caught me off guard because it was easy to think that conversions would produce the same result when reversed.
(3,321 Views)
What I meant to say is
now that you explain it that way I agree it is not a bug
Thanks!
(3,318 Views)
