Nonlinear fitting Initial coefficiencies
Smiley Happy
Hi, everyone, currently I'm working on fitting nonlinear functions. My question is, how do I tell the program to fix some of the initial coefficiencies(I mean accept the value I put as known parameters; they may be treated as known parameter or not, depending on the results)? Any help will be highly appreciated!
Thank you!
Best
Camu
(2,932 Views)
Trying to understand your question : in case the non-linear fit do not converge to a satisfactory solution (as estimated using the mse for instance), you would like the initial coefs to be automatically changed before running the fit again ?
There is no definite receipe for such a problem. You could try generating random values as seeds, after deciding of a working range (average and deviation) for each/some parameter.
Chilly Charly    (aka CC)
(2,916 Views)
Hi, Chilly, sorry for the misunderstanding. Smiley Indifferent
Actually, I just want my program to be more "fancy". Like fitting an bi-exponential decay, there are five parameters in the fitting: A1, t1, A2, t2, and background. However, just like in some other programs (e.g. Origin or FluoFit), not all of the fitting parameters need to be treated as variables. e.g. I knew for sure t2 must be 3ns, then I just want to tell the program, don't treat t2 as a variable this time, just by simply clicking or changing "some state of something" (that's what I'm after) in the program.
Hope this is clear.
Cheers
Camu
(2,912 Views)
