Nonlinear Curve Fit LM Formula String in Labview 8
hi, guys. I write a vi which use Nonlinear Curve Fit LM Formula String. When I run it ,the program says "Syntax error of parser." and I don't know what's wrong with it, so help me,Please. By the way ,you can fill the arrays as you wish.
帖子被trinight在02-11-2006 07:51 PM时编辑过了
(4,611 Views)
You MUST wire initial estimates for the parameters. Attached modification works just fine.
(4,606 Views)
Thank you, altenbach. you seem to know all about Labview 🙂
(4,602 Views)
I am trying to fit the following equation using Nonlinear Curve fit LM: formula string.
a1+a2*x+a3*x*x+a4*c
where a1, a2, a3 and a4 are the parameters to fit while x and c are independent values. x is wired to X in the Nonlinear curve fit.vi. I have a 1 D array of c values for each x. Could you give me some suggestions on how to include these additional 'c' values in the Model description?
Many Thanks
Neeraj
(3,663 Views)
Use the version with the VI model and use the data variant to give the C to the model. You can also e.g. interlace x and c into a single 1D array of twice the length. Again, make sure the model knows how to retrieve it correctly.
Since this thread is well over 10 years old, maybe should start a new thread, attach your code, and explain exactly what the problem is.
(3,653 Views)
Thanks a lot!!! I will try your suggestions and start a new thread for this 🙂
(3,636 Views)
