Non time dependent limit testing
Hi
My problem is I have Varying limits that are not time dependent
eg. When angle is -10degrees, the force should be between -8 and -10 N
When the angle is 0 degres, the force should be between -1 and 1 N
When te angle is 10 degrees th force should be beween 60 and 80 N
Assuming linearity, the force should be within those limits throughout the entire angle range.
I do not know how to go about this and have looked at the mask and limit testing
At he moment my program checks for only those specifc points but I need the entire range to be checked
Any help would be greatly appreciated
Message 1 of 13
(4,552 Views)
Hi Bcousins,
      Please correct me if I'm wrong  - is there a set, or sequence, of force measurements where each measurement is associated with a specific "angle"?  Do you want to limit-test each measurement - but the correct limits depend on the specific angle?  If so, I don't think we have enough info. to know what limits to apply to any angles besides the three you mentioned.  I don't understand how to apply "linearity" to this!
A a bit more info about your DAQ environment might help us!
Cheers.
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 2 of 13
(4,545 Views)
Thanks for you reply
Basically I am assuming linearity between -10 and 0, &,  0 and 10 degrees (for the limits, upper and lower).
I would like to test the limit throughout the entire angle range aswell ( at the moment I just test at the given angles)
The process is testing a spring stiffness with angle. Basically I control pneumatics to rotate a shaft with an angle encoder & torque transducer attached. I get values throughout the entire angle range of the cycle and ,at the moment, am only testing at given angles I know the limits of, which the torque should be within.
I hope that better explains my problem, thnks again
Message 3 of 13
(4,520 Views)
What type of data are you using, waveforms or arrays?? Can you post a picture of your graph??
Message 4 of 13
(4,516 Views)
I'm saving the data as an array in a text file
Mabe this pic will help
Its basically what i want to do - if the data exceeds the limits anywhere - fail
Message 5 of 13
(4,511 Views)
Message 6 of 13
(4,506 Views)
Thanks for the reply
I saw this example yesterday but it seems to only give time on the x-axis and not the values that the good/bad graph shows,
I think I may run into problems with the negative x values ?
Message 7 of 13
(4,504 Views)
Post some sample data and I'll see what it does.
Message 8 of 13
(4,492 Views)
Hi Bcousins,
      The attached VI is pretty simple, Angle-IN, limits-OUT.  The diagram is shown below.
Maybe you can use it with unclebump's code!
Cheers.
Message Edited by tbd on 01-11-2007 11:53 PM
Message 9 of 13
(4,478 Views)
Thanks guys
Unfortunately I do not have any test data on me today - i will have to make up some mock up data
but thanks again for the help
Message 10 of 13
(4,469 Views)
