Non-Latching switch
Is there a switch which does not latch ie the output goes from FALSE
(default) then TRUE and then back to FALSE with some pre-programmable
delay in between? Rather than the usual latching switches.
Tom
(2,814 Views)
Here is a solution using property node. (run continuous or set true before running)
(2,814 Views)
