03-03-2021 08:36 AM
Hello everyone,
I am quite new to labview and I am on a project where I need to import XML data into excel spreadsheet basically.
So I am trying to use the method XmlImportXml with Workbook as reference but I can't find any examples where this method is used and I don't know how to use the entry "Destination" of this method.
Here a visual example of what I am trying to do:
The idea is just to import on every sheet my XML data, so I browse all the sheet and want to import my data with the method XmlImportXml but I can't find a way to give the "Destination" entry a proper format to tell it I want to write at a specific spreadsheet and range.
If someone has an example using this method, I am all for it
Thanks in advance.
Planiste
Solved! Go to Solution.
03-03-2021 09:47 AM
After some research, I find out that my labview code was correct. The only problem here was that my excel sheet already had an array from a previous import therefore the map format didn't match.
Just for information, my value RANGE2 was "A1".
